Oh man do I need help with my 81 240
Old Feb 11, 2008 | 10:47 AM
shwebo's Avatar
Default Oh man do I need help with my 81 240
I have a 1981 240 that has a mysterious problem...
Ever since I did the timing belt and head gasket...
It has broken TWO ps pump brackets, the cast metal plate that bolts to the block. I dont know what it is? The belt was not too tight, there were no signs of wear on the bracket before installation... what could it be?
Here is a picture...
Old Feb 12, 2008 | 11:29 PM
tedv's Avatar
Default RE: Oh man do I need help with my 81 240
There is no logical explanation! If you break a third, call a priest.
Old Feb 13, 2008 | 09:37 AM
shwebo's Avatar
I think I will just drive it w/o PS for a while... Those brackets are hard to come by, and ridiculously expensive online.
Any ideas let me know.
Old Feb 13, 2008 | 10:45 AM
tedv's Avatar
Junkyards!!!
Old Feb 13, 2008 | 07:00 PM
jonesg's Avatar
I'd guess at misalignment, especially you saying ever since you did the timing belt, I'd be looking at the crank pulley. MAybe its not seated right.
I'd try to get the bracket mig welded, its a good excuse to buy a welder too.
Old Feb 13, 2008 | 11:55 PM
shwebo's Avatar
How can I verify that the crank pulley is seated properly? If it isnt... What is the procedure for seating it properly?
Old Feb 14, 2008 | 09:52 AM
jonesg's Avatar
Look at the alignment of the belt from the side.
You sure you put the belt in the right slot?
The crank is keyed onto the shaft with a woodruff key type thingy, if its too far out I'd unbolt it and refit it to be sure its on right.
jiggadude
May 23, 2010 02:11 AM
patomlin
Nov 28, 2007 10:55 AM
casbourne123
Nov 16, 2007 07:50 AM
mariusnagy
Nov 17, 2005 05:27 AM
k8_is_great
Jun 2, 2005 01:24 AM
