Oil in Intercooler
Old Apr 17, 2006 | 03:34 PM
WagHag's Avatar
Default Oil in Intercooler
I've recently removed my intercooler for a good pressure washing and noticed that oil dripped out when I turned it upside down. I also noticed oil had collected in the hose coming from the turbo, and the hose going to the throttle body. The only place I can think of that the oil is coming from is the turbo. Leaky shaft bearing, maybe? Anyone know where I can pick up a turbo rebuild kit for a Mitsu TD04 from a '90 740?
Old Apr 17, 2006 | 09:21 PM
Default RE: Oil in Intercooler
On a turbo car you will always have some oil making it into the Intercooler which is normal.
The new cars come with a small hole drill in it for a drain.
Yours might have a drain plug on it.
Also check the vent system make sure it isn't clogged.
Old May 6, 2008 | 12:18 PM
740SkiWagon's Avatar
I am assuming this oil should be drained out periodically?
I had the same thing happen
Went to drain the coolant and some oil started to come out
my car is a 1990 god knows how much oil is in there
2nd question - i cant find the coolant plug on the back of the passenger side of the engine
should i be looking for it from underneather the car?
65fastback
Jul 25, 2014 04:43 PM
family XC70
Jun 18, 2010 07:04 AM
biteydog
May 2, 2010 02:17 PM
wayne73
Aug 17, 2008 09:43 AM
Derek
Sep 15, 2007 07:34 AM
