Oil Leak
Old Feb 5, 2004 | 01:23 PM
gracechef's Avatar
Default Oil Leak
I have an oil leak from the fill hole on top of the valve cover. Even with a new gasket. Any thoughts on this? Crankcase breather needs cleaning? If so where is it?
Old Apr 1, 2004 | 05:50 PM
pilotsims's Avatar
Default Oil Leak
If its coming from the fill hole on the valve cover, chances of it being the gasket are slim. If you do put a new gasket on, make sure the valve cover is on the head to the correct torque. Looking at a service manual will tell you the correct torque. I have the Bentley service manual for 83-93 240's and the correct torque to tighten the bolts connecting the cover to the cylinder head is 12.5 Nm. If you are sure its not the gasket, it might be that you need a new filler cap? never had this be a problem but you can never be too sure.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
