Oil Light on
Old Jun 10, 2007 | 02:13 PM
oldvolvo's Avatar
Default Oil Light on
What's up with this?
I put a new water pump on my daughter's car today (1989 240DL) and now the freakin oil light is on. Plenty of oil in the engine. Runs as usual, no strange noises.
I've misplaced my shop manual, so I don't know where the oil pressure sensor is. A lot of coolant came out of theengine when I changed the pump, so some may have gotten on the sensor, depending on where it is.
Any help will be appreciated!
Old Jun 10, 2007 | 02:44 PM
oldvolvo's Avatar
Default RE: Oil Light on
OK. Found the manual. Found the sensor. No wire connected to it. There is a loose black wire in the vicinity with no connector on the end. Should I assume that this wire connects to the sensor?
Old Jun 10, 2007 | 03:41 PM
tedv's Avatar
you surely should...
Old Jun 10, 2007 | 04:10 PM
oldvolvo's Avatar
Thanks. So it isthe BLACK wire that connects to the sensor? Didn't see any others that weren't connected to anything.
nuclearseal
Aug 17, 2022 01:48 PM
endneu913
Nov 21, 2010 10:53 AM
glull
Jul 17, 2008 10:51 PM
Jack
Jul 1, 2008 06:15 PM
