Old dog , new trick oil change
Old Feb 27, 2013 | 03:29 PM
jagtoes's Avatar
Default Old dog , new trick oil change
Last year one of my kids bought his Audi A4 home for an oil change. Even though I have a lift in my garage it was a PITA to do. You have to remove all of the plastic covers under the car to get at the drain plug. It adds maybe an extra 20-30 mins to do the change and the oil filter is mounted on top of the engine. So I decided to buy one of the vacuum oil extractors to simplify the process. Well I didn't use it until yesterday on my wife's 89 740GL. So before I started I check the oil on the dip stick and it was full. I inserted the tube in the dip stick tube and pumped the tank maybe 10-15 times. In maybe 5-8 minutes it finished sucking out a little over 4 qts. Stuck in the dip stick and got no reading. Now the interesting part was as it was working I removed the heat shroud and pipe on the exhaust manifold to get at the filter.I put the paper towels under the filter and as I normally do put a plastic bag around the filter as I remove it. No oil came out as the filter was sucked dry too. So being a skeptic I lifted the car and pulled the drain plug and all I got were a few drips similar to when you do a normal oil change.So it looks like I'll be using this on most of our cars.Just an FYI
Old Feb 27, 2013 | 05:32 PM
yeah, I haven't messed with a drain plug at ALL since I got a 'topsider'.
way easy. I've even used it for changing transmission fluid (suck, refill, run engine for a bit in gear to circulate the torque converter and tranny cooler, repeat... 3-4 repeats later its coming out clean, good to go), and even my power steering juice (same thing, suck, fill, cycle steering stop to stop to stop, repeat until clean).
Nickshu
Feb 25, 2013 08:50 AM
KeithS60&V70T5
Nov 11, 2009 07:31 AM
hovonogila
May 21, 2009 09:41 AM
740TurboGuy
Apr 18, 2009 07:19 AM
cnbudz
Oct 20, 2008 03:45 PM
