Any trick to removing rotors?
Old Oct 19, 2008 | 05:49 PM
cnbudz's Avatar
Default Any trick to removing rotors?
I have a 2004 S60 and I was trying to replace my rear rotors today and could not get the things off. I removed the caliper and the one bolt on the front of the rotor. I got the rotor loose but it would not come off. I looked at the new rotors and there is nowhere for something to be attached to the rear of the rotor that could be holding it on. One thing that occurred to me after I put everything back together, and called a garage, was that my E brake had been on. Does anyone know if that was the culprit?
Old Oct 19, 2008 | 05:57 PM
Default RE: Any trick to removing rotors?
Yes the e-brake will stop it from coming off.
There is brake shoes that use the inside of the rotor for the e-brake.
Old Oct 20, 2008 | 10:56 AM
cnbudz's Avatar
Thanks for the help Tech, you just saved me a couple hundred dollars in labor charges.
Old Oct 20, 2008 | 11:13 AM
Did you get them off yet?
They should pretty much slide right off with the e-brake off.
Old Oct 20, 2008 | 03:19 PM
cnbudz's Avatar
ORIGINAL: tech
Just finished up, they came off with a little elbow grease. The entire job took less than an hour for both sides. Thanks for the help!
Old Oct 20, 2008 | 03:45 PM
No problem glad it helped you.
KeithS60&V70T5
Nov 11, 2009 07:31 AM
hovonogila
May 21, 2009 09:41 AM
740TurboGuy
Apr 18, 2009 07:19 AM
mclohman2000
Jan 3, 2009 09:03 AM
rules
Nov 12, 2008 11:40 PM
