One Owner 1989 245 Craigslist Gem in The Making
Old Jun 23, 2018 | 05:02 AM
MSGGrunt's Avatar
Default One Owner 1989 245 Craigslist Gem in The Making
Good inexpensive 240s can still be found if you're ready to buy as soon as you see one.
I just picked up a one owner, 170,000 mile, fully documented, 1989 Midnight Blue wagon. I saw the add on PA Craigslist and had a good feeling about the car. I called the owner and discovered he was the original owner. In late 1988 he went to Keeler Volvo 347 New Karner Road in Colonie, New York and told them what he wanted, specifically, a car with manual windows and a manual transmission. The car was located at Barry Pontiac-Buick 166 Connell Highway in Newport, Rhode Island, put on a truck and shipped to Albany. At the dealership the owner added fog lights, large tach, no small clock, added a volts gauge, oil pressure gauge, third row seat and cruise control. The car stayed in Albany only a year and then moved to PA and that is probably why it is rust free.
As you can see in the photo the owner even kept the original window sticker. The car came with all of its owner's manuals with the maintenance book properly stamped, original touch up paint (purely a novelty item by now), the "what to do in the event of an accident" brochure with the original Volvo pencil, a full set of factory manuals and even the original dealer's key tag with two regular keys and a valet key. What more could I ask for for $1500.00. I drove it 330 miles home and it didn't skip a beat.
The first thing the car will get is a timing belt, water pump, all belts and hoses and a coolant flush along with plugs, dist. cap and rotor. The whole engine compartment needs a good cleaning and detailing. The seat covers will be taken off the seats and washed. The carpets washed and probably redyed. All the plastic appears to be in good condition so that's nice. The rear springs are tired, but I have a new set of overloads from another project as well as new shocks.
The hood is tweaked and will need to be adjusted, the paint buffed and waxed, and just a good all around going over.
In case others are curious about costs of installed options back in 1989 here are the ones installed on this car:
Fog Lights $179.00
Cruise Control $399.00
Tachometer (80mm) $189.50
Oil Pressure Gauge (52mm) $112.95
Voltage Regulator Gauge (52mm) $59.95
Attached Thumbnails One Owner 1989 245 Craigslist Gem in The Making-dscn2248.jpg   One Owner 1989 245 Craigslist Gem in The Making-dscn2278.jpg   One Owner 1989 245 Craigslist Gem in The Making-dscn2280.jpg
Old Jun 23, 2018 | 01:40 PM
lev's Avatar
lev
They are out there, if you look. I just got a 1987 740, 93K miles, one owner and manual trans! Couldn't pass it up. Changing the headliner, putting one in from a 940, keeping it all Volvo and original (much cheaper too).
MSGGrunt
Aug 10, 2018 11:15 AM
wisewood
2001-2013 model year XC70
Jul 13, 2018 08:43 AM
wisewood
Jul 13, 2018 08:31 AM
Brettmcox
May 17, 2018 11:09 AM
vLoke
Jan 10, 2018 05:26 AM
