Overdrive and battery light blinking while driving.
Old May 1, 2012 | 10:37 AM
prosanch's Avatar
Default Overdrive and battery light blinking while driving.
This has been happened off and on throughout the week. The overdrive and battery light will start blinking while I'm driving. Today I decided to press overdrive to see what would happen and both the battery light and overdrive light stopped blinking.
Another thing that happens is the speedometer and rps meter will both start jolting up and down. Giving me false readings. I'm guessing that's because the battery is dying?
When I tested my battery after I pressed the overdrive button (which turned off the blinking battery light & overdrive light) My battery tested at 14 volts.
What could be the cause of this?
Old May 3, 2012 | 11:36 PM
zloetakoe's Avatar
I had similar issues a while ago (flickering lights, speedo jumping around), replaced the alternator, problem solved..
lilsilver85
Aug 29, 2014 04:07 AM
kwatt
Jan 14, 2012 11:57 PM
ForealBoreal
Dec 30, 2010 03:04 PM
thekoopa
Jun 11, 2009 07:18 PM
Brian425
Jun 2, 2006 02:38 PM
