Overdrive Fuse Problem
Old Sep 4, 2010 | 05:55 PM
shyfive93's Avatar
Default Overdrive Fuse Problem
The overdrive fuse keeps popping on me. put a new one in, turn on the key, and it pops. any suggestions?
Thanks, 93 240 5-Door
Old Sep 4, 2010 | 08:55 PM
bigdaddyrdpjr's Avatar
solinoid is hung popping fuse. Change it.
Old Sep 5, 2010 | 02:47 AM
volvoguy2323's Avatar
Banned
You probably have exposed wiring and it's grounding out somewhere. most likely hanging on exhaust...check that first before you replace the solenoid...a bad solenoid will not cause the fuse to blow..
Old Sep 11, 2010 | 04:00 PM
shyfive93's Avatar
thanks guys i will check that stuff out.
Old Sep 11, 2010 | 07:39 PM
Fresheadies's Avatar
Possibly a bad OD solenoid relay if the 240's have one?
lilsilver85
Aug 29, 2014 04:07 AM
shyfive93
Aug 15, 2010 11:49 AM
mischief4l
Sep 2, 2008 07:13 PM
mrchuck85
Feb 28, 2007 09:08 PM
maxhnb
Aug 31, 2006 08:40 PM
