overdrive help 1991 740
Old Jan 15, 2008 | 10:40 AM
gforce's Avatar
Default overdrive help 1991 740
My 1991 740 overdrive lockout seems to kick on at will. Button on shifter will not turn it off. Have replaced relay no luck.
Checked wires at bottom of shifter appear ok. Do not know how to take off the top of ****er to check button. Can I disconnect?
Never us anyway!!!! Thank you for any imput or help. SORRY---auto trans.
Old Jan 15, 2008 | 01:01 PM
tedv's Avatar
Default RE: overdrive help 1991 740
It could be the button, I've seen them gum up and do that. I believe the '91 has the old style pressure fitted button which pulls out by prying it out carefully with a little flat head screwdriver. Once out just clean it and see how it goes.
Old Jan 15, 2008 | 01:46 PM
gforce's Avatar
thank you will go give it a try -- let you know how it turns out!
Old Jan 15, 2008 | 02:23 PM
gforce's Avatar
removed switch, looked fine cleaned anyway. still have no overdrive....arrow light on dash is on when i start the car.
is there a way to bypass or disconnect?
Old Jan 15, 2008 | 03:38 PM
blue goose's Avatar
Same thing happened to me last Friday. Turned out to be fuse #11. Yours may be different.
Old Jan 15, 2008 | 03:42 PM
VolvoMonki's Avatar
yes you can bypasss it
buy this kit which is just a piece of metal
or buy a new o ring and use a dremal and cut the two ports so they are one like in the ipd picture
thats what i did works great
Old Jan 15, 2008 | 06:30 PM
gforce's Avatar
thanks, will give that a try. any tips on getting to the bolts on sylin..... not much room!!
jonc123
Nov 26, 2014 12:00 AM
lilsilver85
Aug 29, 2014 04:07 AM
Northboundndown
Aug 21, 2013 05:42 PM
hardluck
Dec 15, 2012 11:27 PM
doctorc
Mar 12, 2011 05:27 PM
