overdrive not working...
Old Jul 13, 2004 | 02:07 AM
whitetrashsteve's Avatar
Default overdrive not working...
i just picked up an 89 240 DL automatic and the overdrive isn't working. The lil switch on the shifter doesn't stick in one position and i'm wondering if it's an electric overdrive that may just need a switch or relay--or is top gear gone in the car?</P>
i'm not familiar with it...so any help would be appreciated.</P>
thanks,</P>
white trash steve.</P>
</P>
Old Jul 25, 2004 | 05:24 AM
Erock198's Avatar
There is a relay in the dash in the middle for this. Have you checked fuse #11? On the relay you can jump terminal 30 and 87 to have the OD on all the time</P>
</P>
E</P>
Old Aug 13, 2004 | 03:36 PM
hispanic panic's Avatar
Default RE: overdrive not working...
yeah that happened to me. I had to replace the overdrive relay, then the solenoid went out on the button or something, then i soldered some random connections, now the overdrive is permanently on
Old Sep 5, 2004 | 08:53 PM
aseibel's Avatar
Check your fuse. If the fuse is good. Then replace the relay ( which is located to the left of the glove box behind the center a/c vents ). Then check the white wire that runs from the shifter to the overdrive solonoid. A lot of times this wire will loose some insulation and short out against the transmission case. Simply take some vacuum line slit it lengthwise and slide over the bare wire to prevent this from happening.
lilsilver85
Aug 29, 2014 04:07 AM
karajan
Oct 1, 2009 03:25 PM
Walter
Apr 20, 2008 08:45 PM
toplessFC3Sman
Jan 23, 2008 09:46 AM
oldvolvo
Sep 5, 2005 09:56 PM
