Overdrive in a 82' 240 not working?
Old Sep 30, 2009 | 01:48 AM
karajan's Avatar
Question Overdrive in a 82' 240 not working?
Hi, I am a newb when it comes to manual transmission Volvo's but what is the button on top of the gear shifter for a 4-speed manual transmission? I am assuming it is overdrive but it doesn't work. How do you engage it?
Thanks in advance!
Old Sep 30, 2009 | 10:36 AM
tedv's Avatar
When you are under way and in FOURTH, and you wanna go to fifth, step on the clutch and push the button on the shifter. A green light should light up on the dash, and you shold be in FIFTH gear, RPM should drop, etc.
Old Oct 1, 2009 | 01:40 PM
karajan's Avatar
All right, I took it for a drive, and did what you suggested but the OD does not engage. Should I be following the post that Fresheadies had posted? And the info from this link? https://volvoforums.com/forum/showthread.php?t=34866
BTW, what kind of transmission does my car have?
Thanks in advance!
Old Oct 1, 2009 | 03:25 PM
bubba240's Avatar
The other post has to do with the auto transmission which is different. Do you ever see the OD light come on after pressing the button? If not check/replace fuse 11. If it still doesn't work you'll need a volt meter and a wire diagram.
Your car has the M46.
lilsilver85
Aug 29, 2014 04:07 AM
gthornton
Dec 5, 2012 11:32 AM
toplessFC3Sman
Jan 23, 2008 09:46 AM
oldvolvo
Sep 5, 2005 09:56 PM
whitetrashsteve
Sep 5, 2004 08:53 PM
