Overdrive problem here too
Old Jul 3, 2006 | 04:02 AM
jdhore1's Avatar
Default Overdrive problem here too
I'm having a overdrive problem on my automatic 86 Volvo 240DL Wagon...no matter what i do, the OD off light on the dash stays on and i can't tell if the OD is on, off or if the light is just malfunctioning and the button on the side of the shifter does nothing
Old Jul 3, 2006 | 09:42 PM
Default RE: Overdrive problem here too
Have you checked the relay yet?
Old Jul 3, 2006 | 11:11 PM
jdhore1's Avatar
nope, haven't checked anything yet...i was more or less wondering if it was a semi-common problem or if the OD is really on or off...thanks
Old Jul 4, 2006 | 12:12 AM
First thing to check is the relay.
Usually when the relay goes bad Overdrive won't work.
Old Jul 6, 2006 | 12:35 AM
jktiffin's Avatar
Same problem with my 86. An easy fix with a new relay. This also fixed the button on the gear shift that would not stay pressed in. A simple cheap fix
lilsilver85
Aug 29, 2014 04:07 AM
Sir James
Nov 7, 2012 03:38 AM
djcass4199
Jul 9, 2009 10:16 AM
Eric
Jan 19, 2006 08:41 PM
VolvoLisa
Feb 7, 2005 08:01 PM
