Is this part of the intake?
Old Dec 1, 2008 | 05:43 PM
qstyle's Avatar
Default Is this part of the intake?
I was checking my idle air control valve and noticed something. i have a 82 245 wagon with B21f engine. Anyhow i took off the above mentioned and looked almost straight down between my intake manifold and saw a open ended rubber piece with all this white dirty goop stuck in it, i was able to pull off the the rubber piece and it looks like it was connected to a plastic opening which is also has alot of gunk inside of it. what is this? and was something else supposed to be connected to the wide side of the rubber piece? the thin side was on the plastic piece. Im sorry this is so vague , im just trying to discribe it the best i can.
Old Dec 2, 2008 | 12:32 AM
dgm76513's Avatar
Default RE: Is this part of the intake?
I could be wrong, and I'm sure tech will correct me if I am (thanks in advance :P) But I believe that to be your PCV/Flame trap. Clean it very well.
Old Dec 2, 2008 | 07:56 AM
Is the hose you speak if really big like almost the size of a dryer hose?
Or a smaller hose like a PCV hose?
Old Dec 2, 2008 | 09:50 AM
qstyle's Avatar
thanks for the responses , the hose isnt big and the part that i pulled off is a little bigger than the end that connects to the ignition coil but a similar shape. i didnt pull off any hoses, its just a rubber piece that has openings on both sides , the side facing down slid onto the plastic piece and the other side was facing up with the end wide open . its in a location that is very difficult to get at, any suggestions? are there hoses connecting to the plastic piece that this thing connects to?
matt
Old Dec 2, 2008 | 10:02 AM
That might be for the Vent box system I am just trying to picture it in my head from your description.
Old Dec 2, 2008 | 10:36 AM
bubba240's Avatar
http://www.fcpgroton.com/category-ex...16/by_year/32/
I think you are describing the flame trap (PCV). A disconnected vaccum line may be causing your stall problems. The flame trap has 2 connections - a small vac line "after" the throttle plate and a large line "before" the throttle plate. Maybe post a picture. Check the VIN chart attached to see if you have the CI or LH fuel system.
[IMG]local://upfiles/15703/C501AAA540A1423587685F6CF345D66D.jpg[/IMG]
[IMG]local://upfiles/15703/205C6F70D2F542F1AB5FAA4797C0C1BF.jpg[/IMG]
Old Dec 2, 2008 | 11:47 AM
qstyle's Avatar
thanks for the help guys, im really stuck here. I have the B21F-9 which it appears to be the CI system and Chrysler ignition system. i looked up the part and the rubber piece looks to be part of a flame trap kit. The narrower end of the rubber piece fits over a plastic piece and the wide end isnt connected to anything.
How do i replace this or clean it? Also how do i get access to clean the throttle body? I do have a book but it doesnt tell me how to remove the throttle body or gain access to the flame/oil trap or whatever thats called. thanks again for your help.
Old Dec 2, 2008 | 12:31 PM
tedv's Avatar
It's the flame trap alright, and it sounds like it has fallen apart completely. It's a pain to work down there, and believe it or not taking the intake manifold off is not as hard as it sounds. Then you can really get to the trap and see what you got.
Old Dec 2, 2008 | 12:44 PM
qstyle's Avatar
so what hose if any is supposed to be connected to the wide-endof the rubber piece that fits on the flame trap?
Old Dec 2, 2008 | 12:53 PM
tedv's Avatar
This has some info:
http://www.volvoadventures.com/images/crankcasevent.jpg
Old Dec 2, 2008 | 01:05 PM
bubba240's Avatar
ipd has a good diagram:
http://www.ipdusa.com/Volvo-200/Filt...-260-847-3317/
[IMG]local://upfiles/15703/ED595ED911B34B0D82DD53E498A14C06.jpg[/IMG]
Old Dec 2, 2008 | 01:35 PM
qstyle's Avatar
This maybe kind of a dumb question but how do i know whether i have K-jetronic or LH?
Old Dec 2, 2008 | 01:39 PM
TIPSP's Avatar
Got Boost?
K-jet has a mess ofhoseson top of the air box.
Here is an example: Pic of a VW
Old Dec 2, 2008 | 01:54 PM
bubba240's Avatar
K-jet and the CI system are the same thing so from your VIN number you have the K-jet. 82's had both.
Jeff Kong
1998-2000 model year V70
May 18, 2012 05:38 PM
Stefan1235
May 21, 2011 09:00 PM
rquinonez32
Sep 30, 2008 02:08 PM
fibzzz
Mar 1, 2008 11:51 PM
JBVolvo
Apr 6, 2007 10:17 PM
