passing emissions
Old Dec 29, 2013 | 10:28 AM
MEWEAVER's Avatar
Default passing emissions
I have to pass an emissions test to get my tags. How do I get the check engine light off on a 1990 740 gle.
Old Dec 29, 2013 | 10:46 AM
jagtoes's Avatar
I don't believe you have an OBDII connector so you would have to delete the code through the Diagnostic block in the engine bay. Also what are the codes when you check them as this is a pretty basic system. Also what state/country are you in that looks at check engine on a car older then the OBDII system which started in 1996.
Old Dec 29, 2013 | 11:35 AM
MEWEAVER's Avatar
I have'nt checked the codes yet, but I'm in Chattanooga Tn and if the check engine light is on you fail.
Old Dec 29, 2013 | 12:04 PM
TIPSP's Avatar
Got Boost?
Take the bulb out. Then put it back after test.
Old Dec 29, 2013 | 03:21 PM
how to read and reset OBD-I codes...
Engine and OBD Diagnostic Codes
Old Dec 29, 2013 | 04:51 PM
jagtoes's Avatar
Interesting as I thought NY was pretty tough but any car before 1996 doesn't get inspected for emissions other then verifying it has the cat .
Old Dec 30, 2013 | 09:35 PM
lev's Avatar
lev
Disconnect the battery for 20-30mins--easiest way.
The OBDI reset is very hit and miss; many times it doesn't work.
Taking the bulb out doesn't work as the light is part of the system and has to be ON, then go OFF.
Old Dec 30, 2013 | 09:42 PM
I've never had any problems resetting the OBD-I on several cars, just follow the procedure carefully.
now, theres a lot of codes that will come right back after a short test drive, like o2 sensor out of range, ECT out of range, and so forth. those will need to be fixed.
dieselsnowmobile
Nov 30, 2011 05:48 PM
fixitpimp
Apr 20, 2009 06:05 PM
usawebx
Sep 2, 2008 06:11 PM
Psaboic
Jun 6, 2006 01:34 AM
UnDeR EsTiMaTeD
Sep 27, 2004 12:02 PM
