popping the hood
Old Nov 26, 2005 | 12:10 PM
beast_wit_ze_least's Avatar
Default popping the hood
Hello all. I'm new here, just joined in Thanksgiving. I have a couple of questions. First, what's the proper way to clean an air filter? Also, my hood popper handle doesn't work. I yank on it, and it won't pop the hood unless someone is standing at the hood pulling up on it. Is this the way it's supposed to work on a 92 240?
Old Nov 26, 2005 | 09:13 PM
matthewensey's Avatar
Default RE: popping the hood
Welcome to the forums! Unless you have a K&N Air Filter, which is cleanable, you should just replace your filter. Shouldn't be but a couple dollars for a new one. The installation takes 2 minutes also. No, the hood should not have to be pulled on to "pop it" from inside the car. Sounds like the spring mechanism that pushes the hood up when you pull the lever is malfunctioning. The first thing you could do is spray some WD40 on the "hook and spring" mechanism under the hood. That will insure that certain parts aren't getting hung up from time. The next step would be to replace the mechanism itself.
Old Nov 27, 2005 | 01:42 AM
Red XC's Avatar
you can temperory clean the air filter by using a shop air nozzle or just hit it like a carpet.. to get some of the dust out. Replace it once you have the part.
JeannieBeannie
Mar 6, 2019 01:29 PM
MDUBBSS70
May 28, 2014 09:02 PM
Red Tractors
Aug 20, 2013 10:33 PM
850TurboWgnPlatEd
Nov 5, 2008 12:52 PM
JimKW
Jul 29, 2005 09:16 PM
