Power Antenna
Old Jul 23, 2009 | 11:09 AM
DVTO's Avatar
Unhappy Power Antenna
I replaced the entire power antenna assembly about 6 months ago with the $200 one from FCP. It was installed by a Volvo shop and worked perfectly up until two months ago.
Most of it rises and falls fine. The top tip of it stays "out" the same amount (about 1.5 inches) regardless of whether the antenna is up or down. What can I do to fix this?
Old Jul 24, 2009 | 12:50 AM
Titan Joe's Avatar
It should be oiled every now and then. Use WD40 and a rag. Run it up, spray it a little, run up and down a bit, add a little more if needed and wipe up off excess with a rag.
bsobo
Apr 20, 2010 08:18 PM
alecw81
Jan 7, 2009 05:22 PM
Wing
Jan 31, 2008 10:13 AM
snulma1
Sep 25, 2006 09:04 PM
armoredsaintt
Feb 18, 2004 01:54 AM
