Power seat not working
Old Mar 6, 2023 | 08:40 PM
Freshscott's Avatar
Default Power seat not working
Hi there, I’m working on some friends 93 940, it’s got a power driver seat with memory, non of the functions (forward and backwards, up and down, and backrest up and down) work, I’ve checked the fuses and they are good, and I have verified the plug in to the seat is getting power and all the way till it plugs into the module under the seat, I’ve pulled both the switch and the module apart and don’t see any signs of a short circuit, I’m not the best with electronics, and was curious if anyone had any insight on how I could test to narrow the problem down further?
Old Mar 6, 2023 | 10:01 PM
lev's Avatar
lev
It's likely the large square module under the seat, is that what you are referring to as appearing to be OK? I'd change it see what happens.
Old Mar 7, 2023 | 07:09 AM
Freshscott's Avatar
when you say the large square module under the seat, are you referring to the black one that hangs under the seat, or the really big green one that is bolted to the floor? also do you know a way to test that module?
Old Mar 9, 2023 | 01:03 PM
lev's Avatar
lev
The one I refer to is usually green and it is attached to the underside of the seat, it wouldn't be attached to the floor. The one on the floor is probably the SRS module.
ingydrummer
Feb 28, 2014 07:44 PM
Jermaine Shaffer
Interior
Sep 4, 2013 04:40 PM
tesalona
Apr 10, 2011 10:50 AM
Beachbum
Aug 21, 2010 11:33 AM
lenniefoug
Aug 6, 2005 04:33 PM
