power stage, map sensor...whats the difference?
Old Feb 20, 2006 | 11:38 PM
jfunez's Avatar
Default power stage, map sensor...whats the difference?
does anybody know if there is a difference between a regular GM map sensor and a so called power stage? they both seem to be the same thing...is there any difference in maybe tha calibration or reading of the manifold pressure that these two give out..?
Old Feb 20, 2006 | 11:53 PM
Default RE: power stage, map sensor...whats the difference?
A power stage has nothing to do with vaccum. There is no vaccum line that goes to the power stage.
The power stage controls the ignition system.
Old Feb 21, 2006 | 12:58 AM
jfunez's Avatar
ok im confused.. im sure u know what im talking about...the map sensor covered with metal... any difference?
Old Feb 21, 2006 | 01:01 AM
jfunez's Avatar
this is on a 1990 ...940 2.3 non turbo
would replacing it with a Gm map sensor make a diff.?
Old Feb 21, 2006 | 08:54 PM
I haven't tried as of yet.
Do they look 100% the same besides the metal cover?
Alot of GM parts were used on a lot of cars and just changed a little to be made their own.
Here is a story for you. My old Shop manager has a Lotus. The ignition module went bad. Lotus wanted $375.00 for the module.
When he looked at it it was just a GM ignition module that was glued to a peice of Alimunum.
The GM part at the local Parts srore it was $15.00.
Old Mar 5, 2006 | 02:32 AM
jfunez's Avatar
it worked, a 70 dollar GM part, which in fact i got for free since I work there,can be replaced in place for the $170 volvo map sensor.they are Identical and work great..
Old Mar 5, 2006 | 03:16 AM
Cool glad all went well for you.
iatotofts
Mar 15, 2010 10:27 PM
bunky3301
Apr 3, 2008 03:06 AM
Patdon10
Oct 20, 2007 09:32 PM
bne
Feb 26, 2006 01:54 PM
