2002 s80 Brakes-bleeding
Old Jul 8, 2007 | 01:44 PM
Dalbery's Avatar
Default 2002 s80 Brakes-bleeding
Hello,
I just installed new cross drilled and slotted rotors on my wifes 02 S80. I had to crack the bleeders open on the front in order to expand the calipers over her severely gouged rotors. I bled her brkea last night and then vacuum bled her brakes and the pedal still goes almost all the way down. I must have air in the lines still. Are there any tricks to bleeding these brakes? Any Help will be appreciated.
Thanks,
Darrell
Old Jul 8, 2007 | 04:53 PM
billofdurham's Avatar
Default RE: 2002 s80 Brakes-bleeding
Did you do it like this?
I have never seen this method of brake bleeding but this is what is on VADIS:
[IMG]local://upfiles/4491/5E61C55453B240F5A3EF74079D834F3E.jpg[/IMG]
Old Jul 10, 2007 | 08:23 PM
Dalbery's Avatar
Update: I took the car to a brake shop today and had them bleed the brakes. They had the same results I did. They told me the master cylinder is bad. Something about the primary port not functioning only the secondary port. Does this sound right?
Thanks,
Darrell
macitect
Jun 18, 2009 03:50 PM
jackief288
Jul 21, 2008 08:14 PM
rene
Dec 7, 2007 01:10 AM
Air Defender
Jan 29, 2005 07:45 PM
djbaines
Nov 10, 2004 06:43 PM
