??Problems with my 1990 740
Old Nov 17, 2007 | 09:50 AM
gabyman97596's Avatar
Default ??Problems with my 1990 740
Ok the problem is the car sometimes start sometimes don't when running the car stalls or when on idle. No check engine light I can hear the bomb perfectly the coil has spark but on the ignition cap if I play with cable that goes from the coil to the ignition it start misfiring how do I know its the ignition cap its going bad any help would be aprreciate it
Old Nov 17, 2007 | 09:57 AM
Default RE: ??Problems with my 1990 740
I would do a full tuneup and take it from there.
Old Nov 17, 2007 | 09:59 AM
tripleb's Avatar
Sounds like the coil wire is bad. It's possibly arcing to ground, so be carefull you dont get shocked!
Old Nov 17, 2007 | 10:00 AM
That car has everything I put new spark plugs less than one month air filter, gas filter, even rebuilted the tranny less than a month and now this??? any ither suggestions???
Old Nov 17, 2007 | 10:10 AM
You did new cap,rotor, and wires?
If so are they good quality?
Old Nov 17, 2007 | 04:03 PM
Ok the car has good spark on all four pistons,cap and rotorok, I can hear the fuelpump noise under the car so I Sprayed some carburator cleaner in the throttle and the car tried to start but didn't stay onDon't know what could be causing this. !!help please
Old Nov 17, 2007 | 04:20 PM
If the Carb cleaner started it then it stopped it means not getting fuel.
Could be injector relay or speed sensor.
Old Nov 18, 2007 | 07:40 AM
Tech Where are this items you mention located in the car???
Old Nov 18, 2007 | 07:58 AM
The injector relay should be on the passenger side attached to the coolant bottle.
You might have 2 of them there. One is a cooling fan and the other is the injector relay.
The speed sensor is located at the back of the engine in the top of the transmission bellhousing.
Old Nov 18, 2007 | 08:01 AM
The one you said that is on top of the trans is the same as crank sensor right?? How can I test if the relay is bad???
Old Nov 18, 2007 | 08:05 AM
Yes crank sensor.
If you have 2 of the relays just swap them for now and see if the car starts.
Old Nov 18, 2007 | 08:35 AM
Tech it was the relay from the espandion tank i cleaned it with contact cleaner give it a few tabs and the car started righ away thanks for ur help!!!!
Old Nov 18, 2007 | 08:38 AM
Glad you got it.
mattem
May 14, 2020 08:39 AM
dswhelan
Dec 24, 2015 12:36 AM
craigshensel
Jun 13, 2012 03:11 PM
volvoQ's
Sep 26, 2010 01:45 AM
aimeesvolvo
Apr 25, 2009 01:10 PM
