Pulled Codes and suspect Oxy Sensor
Old Oct 24, 2005 | 05:24 PM
colgate41's Avatar
Default Pulled Codes and suspect Oxy Sensor
On my way home from school today i was on the parkway doing about 60 when my car just shut off. I pulled to the side jiggled the fuel pump relay fuse heard the hissing and started my car right back up. The Check Engine light is now on and i pulled a code of *2-3-2 if i remember correctly. This means the Oxygen Sensor or leaking fuel injectors. But also when i first went to pull a code i put the wire into the #2 hole and i heard a loud ticking sound comming from the middle of the engine, and i cant figure it out.
Thanks
Old Oct 26, 2005 | 12:30 AM
Default RE: Pulled Codes and suspect Oxy Sensor
Look at the fuel pump relay.The production date is stamped on it. If it is original I would replace it ASAP.
232 most of the time means a vaccum leak. I know many books tell different things but they all lead to a vaccum leak.
If you really want to check the O2 sensor If you have a 1 wire sensor you can test it very easy with a voltmeter.
The ticking im not sure about.
Old Oct 26, 2005 | 12:51 AM
colgate41's Avatar
Yes Tech, i suspect the Fuel pump relay heavely. I pulled it out and yes it is from 1990, and i would really like to replace it but im not sure where yo buy a new one.
Old Oct 26, 2005 | 01:16 AM
Check an import Auto Parts store they should carry one. If not then the dealer.
Old Oct 26, 2005 | 01:21 AM
colgate41's Avatar
Thanks again!
Old Oct 26, 2005 | 01:25 AM
No problem
Old Oct 26, 2005 | 01:36 AM
colgate41's Avatar
Tech, i found some on ebay brand new for a good price, so i will be getting a new one soon. You said something about a vacume leak? Where would this be located? Hoses? What should i do to fix the leaks, if any?
Old Oct 26, 2005 | 08:28 PM
You can spray around with carb. cleaner with the car running.Listen for an idle change and then there is a leak.
Check all hoses and the intake manifold at the engine.
Bobby Grady
Jan 6, 2013 04:00 PM
chef
Jan 18, 2009 10:21 PM
jbnery6465
May 22, 2008 05:23 PM
topdwn
Jan 24, 2006 10:39 PM
colgate41
Aug 14, 2005 01:01 PM
