Questions an owner's manual would answer, but a Bentley manual doesn't
Old Dec 1, 2008 | 10:02 PM
Jimal's Avatar
Default Questions an owner's manual would answer, but a Bentley manual doesn't
As the title eludes to, I have a Bentley for my '85 245 but no owner's manual. Because of this I'm flying blind. Could someone tell me:
1. Should the ignition/door key also lock/unlock the security cover behind the rear seat? I can't get my key in. Before I take it apart it would be nice to know the key should work.
2. Is there a delay setting for the rear wiper? I have on and off, but there is a third position that doesn't seem to do anything.
Thanks,
Jim
Old Dec 1, 2008 | 11:31 PM
TIPSP's Avatar
Got Boost?
Default RE: Questions an owner's manual would answer, but a Bentley manual doesn't
1: The owners (master) key should be able to open everything. Someone might have changed the lock. I had a similar problem with my car...it turned out that someone replaced the lock for the glove box and I had to get a whole new set of keys.
2: I believe it should be on/ off/ fast mode.
Old Dec 2, 2008 | 06:11 AM
Jimal's Avatar
1. Thanks
2. Right now I have on, off and off.
Jim
Old Dec 2, 2008 | 09:47 AM
TIPSP's Avatar
Got Boost?
I think it should be on/ off/ fast mode.
My car is a 740 but I am sure they are the same.
Something is wrong.....but what....I couldn't tell you.
I haven't messed with it that much, and I rarely use mine anyways
Old Dec 2, 2008 | 10:19 AM
Jimal's Avatar
Copy. I have a broken wire sticking out of the passenger side hinge on the tailgate. I assumed it was for the defogger, which isn't working right now as well. The plan is to splice it back together the next time I have some free time and (relatively) warm weather. Perhaps that will fix the wiper issue instead, leaving me to break out the DVOM to solve the defroster. Or the other way around.
Jim
Old Dec 5, 2008 | 02:40 AM
Sofar.'s Avatar
The third position operates the rear window sprayer.
Old Dec 5, 2008 | 12:19 PM
TIPSP's Avatar
Got Boost?
I thought that there is a little button on the side that works the sprayer. maybe it is just like that on 700 series.
Old Dec 5, 2008 | 01:46 PM
billofdurham's Avatar
You can find an on-line Owner's Manual at:
http://new.volvocars.com/ownersdocs/...o/85240_00.htm
Old Dec 5, 2008 | 06:47 PM
Jimal's Avatar
Excellent! Thanks for the link. BTW, my car also has a button at the end of the stalk to control the rear window sprayer.
Jim
Old Dec 5, 2008 | 07:15 PM
TIPSP's Avatar
Got Boost?
ORIGINAL: Jimal
Jim
That reminds me...I think mine is broke. I don't thinkmy button has been pushed in 10years
Old Dec 5, 2008 | 10:05 PM
blue goose's Avatar
The wiring for the defogger, third brake light, and license plate light are on the left (driver's) side.
The wiring for the wiper motor and tailgate lock are on the right side.
Old Dec 7, 2008 | 09:29 AM
Jimal's Avatar
ORIGINAL: blue goose
Hmm... the mysterious wire is sticking out of the right hinge, but it is my defogger that isn't working. The wiper (except the intermittant setting) and license plate lights work fine. My car is an '85 so there is no third brake light. I haven't checked the wire for voltage yet, so I can't say for sure what it does. All I know is that it is black.
Jim
P.S, This forum doesn't seem to like apostrophes and quotation marks.
Old Dec 7, 2008 | 01:23 PM
blue goose's Avatar
Sorry, Jimal. I missed that it was an '85.
My "three on the left, two on the right" routine are for the '86. Not sure about '85.
One time my defogger didn't work but the wiring through the hinge was fine. Turned out to be the wiring inside the tailgate.
Old Dec 7, 2008 | 03:50 PM
Jimal's Avatar
No worries. I really haven't had a chance to study the schematics yet or even to poke around with the wiring.
Old Dec 7, 2008 | 09:52 PM
obaloney's Avatar
Jimal,
Wiring in the tailgate hinges on 245s are notorious for breaking. The colored wires control just about everythingwipers, washers, defroster, etc. There also are two black wires, one on each hinge. Those are the ground wires. As long as one of them is intact, you're OK. If they're both bad, you have no ground and nothing will work.
There are two ways to fix any broken wires going to the rear wiper, etc. 1. Buy new wiring harnesses and thread them all the way through, which means removing the hinges and headliner (a bitch of a job). 2. Pull back the corner of the headliner near the wires, cut the wires and reroute them, bypassing the hinge. I did that recently on my 93 245, which had several broken wires. You can tape things up after rerouting and it doesn't look too bad. And it cost me nothing.
You are not going to be able to just fix a wire or two on either side and keep them in the hinge. they are too tightly together and will just break again if you try to solder them. If you have any broken wires, I recommend just rerouting them all and bypass the hinge.
Old Dec 8, 2008 | 06:58 PM
Jimal's Avatar
Good to know. Well my wiper works, so I guess I have one good ground. I need to go out there with a test light or my DVOM to check the defroster grid. All I know is this one black wire is sticking out of the hinge by a good inch. Something to do this weekend I guess...
Jim
Old Dec 12, 2008 | 08:05 PM
  #17
Jimal's Avatar
Broke out the test light today and I am getting power to the defroster grid. I'm not sure if this was always the case or the result of replacing all the fuses (some were corroded). I'll have to wait until the next time I need it, but the impression I was getting there are some breaks in the grid, or that broken wire completes the circuit. If I can pull down the headliner without damaging it I might try patching that wire. I know, I know, I'm a glutton for punishment.
As for the wiper delay, I ordered up a used replacement along with a replacement LF bumper strut. I'm taking care of little odds and ends until Spring.
-Jim
Jimal
Jan 26, 2009 10:26 AM
montysano
Jan 7, 2008 02:47 PM
montysano
Nov 14, 2007 07:07 PM
jdbs3
Oct 30, 2007 07:30 AM
ktmrider193
Apr 30, 2007 11:34 PM
