Rear wiper doesn't touch window- adjustment help??
Old Jan 19, 2010 | 08:22 AM
Beemer2002's Avatar
Default Rear wiper doesn't touch window- adjustment help??
Does anyone have any tips on making my rear wiper make contact on rear window? Should I try to bend- or is there an adjustment process? THANKS!!!!
1994 940 TW
Old Jan 21, 2010 | 06:28 AM
act1292's Avatar
There is no real adjustment on these. The spring in the wiper arm is supposed to keep it on the glass. A lot of times what will happen is the joint near the base of the arm will get all gummed up and corroded. It doesn't flex very easy and the spring can't do it's job.
I suggest that you lube up this joint and flex it until it loosens up. Then the spring should be able to keep it on the glass.
Old Jan 21, 2010 | 09:52 AM
Beemer2002's Avatar
THANKS!! Yes, there is no flex whatsoever- I'll have to get creative to lube it up
mafraziersr
2001-2013 model year V70
Jun 26, 2015 07:05 PM
FXMV40
Mar 6, 2013 10:31 AM
steve911
Oct 11, 2011 08:13 AM
Johnny Volvo
Jun 21, 2011 10:14 PM
Snowboater
May 10, 2011 01:28 PM
