Wiper does not touch Windshield V40
Old Mar 6, 2013 | 10:31 AM
FXMV40's Avatar
Default Wiper does not touch Windshield V40
Hi, I am experiencing a strange occurrence on my 2002 V40. The passenger wiper blade lays flat against the bottom of the windshield when turned off, however when I engage the wipers the passenger side moves totally off the windshield about half-way through its movement. There is a good 1 inch gap at the high point.
I have removed the nut and secured the arm to the threaded pinion securely, and attempted to adjust it to no avail. I have checked to make sure the spring mechanism is not impeded and that the arm if fully engaged. So far no luck.
I am wondering if the arm was replaced at some point prior to my ownership, and if it is possible that it was replaced with the drivers arm and somehow they have a different shape. It almost seems that the passenger arm would need to dip into the windscreen.
Has anyone encountered this issue? Are the two arms, driver & passenger materially different other than driver being slightly longer? Do I just bend the passenger arm so it pushes down more? Something seems out of whack. Any suggestions would be helpful. Thanks
rspi
Jan 11, 2014 06:22 PM
Dr.JellyFinger
Dec 17, 2011 02:39 PM
Johnny Volvo
Jun 21, 2011 10:14 PM
Snowboater
May 10, 2011 01:28 PM
Beemer2002
Jan 21, 2010 09:52 AM
