Wiper wont touch half the drivers side windsheild
Old Sep 15, 2010 | 05:55 PM
Snowboater's Avatar
Default Wiper wont touch half the drivers side windsheild
I think it's a simple matter of adjustment (now that I jinxed myself), but on my 1997 850 T5 Wagon the driver's side wiper goes airborne as it passes the middle of it's stroke (exactly in the primary field of view). The springs are tight and the mechanism is not binding, but the wiper won't stay on the windshield (and it goes quite a ways off - 1/2"ish). I tried it in the driveway & at 90ish - same result except the later was a lot more fun. Can I shim the wiper motor on its mounts? Thanx for the help...
Old Sep 15, 2010 | 06:42 PM
My car was doing that when I first purchased it. What I did was took the wiper arm off and bent the lower bracket a little then re-installed it. Fixed!
Old Sep 15, 2010 | 08:14 PM
Snowboater's Avatar
Great idea I'll try it!
Thanx
Old Sep 15, 2010 | 08:26 PM
boxpin's Avatar
another way is at the pivot point you can see where the problem is. The arm makes contact with the mount and stops it from further travel. If you pull the arm away from the window then put a flat blade screw driver in the joint between the contact point then lower the arm bending the arm contact point just enough to let the arm travel all the way down. Will take a couple times to get it where you want it. Slow and easy.
Another way would be to shave the contact points on the mount.
Picture: If you look closely you can see my bends.
Attached Thumbnails Wiper wont touch half the drivers side windsheild-img_0221%5B1%5D.jpg   Wiper wont touch half the drivers side windsheild-img_0222%5B1%5D.jpg
Old Sep 16, 2010 | 06:09 AM
Sweet. I'll have to check that out. How does that get out of wack over time?
Old Sep 16, 2010 | 11:46 AM
JimKW's Avatar
I have taken mine off, put it in a vise and bent it every so slightly. Works fine. Had to redo it on one of mine just the other day.
Old May 10, 2011 | 11:26 AM
hookuspookus's Avatar
i was just looking to see how to fix that on mine ! yours is a nice EASY fix i'll try it !
Old May 10, 2011 | 11:36 AM
Default THE Boxpin fix ,right on target !
From what iv'e gathered the bushing in the housing starts to enlarge and the shaft starts to pull back . i tryed bending the wiper arm but i think you need to be superman . i'm trying Boxpin's method with bending it at the arm stop with the screw driver ,i was going to buy a dremel and grind it down but i think his way is MUCH better ! is there anything a screwdriver can't do ?
Old May 10, 2011 | 11:38 AM
and yes i know the post is old
Old May 10, 2011 | 01:28 PM
JimKW's Avatar
I'm teling it does not take much to bend it just very little. I could not believe how little it took to make it hit all the way through the stroke.
mafraziersr
2001-2013 model year V70
Jun 26, 2015 07:05 PM
FXMV40
Mar 6, 2013 10:31 AM
Johnny Volvo
Jun 21, 2011 10:14 PM
Beemer2002
Jan 21, 2010 09:52 AM
95pimpwagon
Jan 20, 2006 01:09 PM
