Recline retainer
I need to get my drivers seat reupholstered. It is far cheaper to be able to bring in just the fabric and put it back on myself. So, I need to remove the seat fabric but I don't know the technique for removing the retainer on the recline ****. Anybody have any ideas? I will see if I can get a picture up soon.
The retainer is a flat disk that goes over a small diameter rod with a groove cut in it. The four fingers on the retainer go into the groove and this keeps the recline **** in place.
I have gotten them off in the past by mangling them but there has to be a better way.
are you talking about part 29 in this diagram?
looks to be a $8 part.
Frontseat. Fits: Volvo | VolvoPartsWebstore.com
Thanks for the drawing Pierce. It looks to be 38. It is a small flat steel disk with 4 holes in addition to the hole in the center with 4 retaining fingers. I managed to remove it by inserting two sheetmetal screws into two of the holes and pulling an twisting with Vice-grips on the screws. It came off in good enough shape to reuse.
Next step is looking for a good upper foam piece. Someone had these new. I will probably look to see if I can get a cheap passenger seat at a yard first. Then in addition to the foam, I'll also get some other bits.
Thanks for the reply Lev. Even when the advice is that it is a difficult task, it still helps. At least I feel like I am not the only one struggling. BTW I found the technique that I used on Turbobricks.
gilber33
Mar 16, 2011 12:54 AM
