Remove small clock to right of instrument cluster
Old Sep 22, 2013 | 11:03 AM
schultkl's Avatar
Question Remove small clock to right of instrument cluster
1984 244 GL, with a tachometer, spedometer, and battery/fuel guage clusters.
How do I remove the small clock to the right of the instrument cluster?
I.e., do I need to remove the instrument cluster to access the rear of the small clock, or can I pop the black plastic bezel in front of the small clock and simply remove screws to remove?
It's my neighbor's car and I don't want to mess it up. : o \
Thank you
Old Sep 23, 2013 | 12:25 AM
you have to get at it from behind. 2 finger nuts on the back of the clock secure a bracket that clamps it against the dash panel. you /might/ be able to reach up from behind/under the dashboard, but ugh, be much easier with the instrument panel out. when you take the trim bezel off the clock, and the blank panel under it, and the ones near the light switch, the screws that hold the 86+ instrument panel are exposed. I assume the older ones are similar?
at least thats how an 87+ is, I've never taken a 84 apart.
rspi
Jun 29, 2012 12:12 PM
volvo5volvo
May 29, 2012 05:46 AM
962ym
Oct 20, 2011 03:40 PM
njmotorguy
Apr 30, 2009 07:08 PM
Davidjwhitcomb
Feb 7, 2009 12:37 PM
