LCD clock, mileage, etc. in instrument panet
Old Jul 4, 2010 | 07:02 AM
962ym's Avatar
Default LCD clock, mileage, etc. in instrument panet
Hi all, replaced my odometer gear and the the dash bulbs. Everything works except the LCD panel lights at the bottom of the panel. Bulbs are good - all connection made. Any suggestions?
Thanks
Old Jul 6, 2010 | 01:15 PM
Default LCD trip info
My trip information LCD panel works but thought I'd ask if anyone knows if it's supposed to be lit up? Works fine just can't read it at night. Is there a replaceable bulb in there to light it up with the headlight on? If so, any link to a "how to" on getting to it?
Old Jul 6, 2010 | 04:17 PM
vjaneczko's Avatar
My trip information LCD paned works but thought I'd ask if anyone knows if it's supposed to be lit up? Works fine just can't read it at night. Is there a replaceable bulb in there to light it up with the headlight on? If so, any link to a "how to" on getting to it?
Bulbs are burned out. There are two bulbs to replace - and plenty of write-ups to read how to do it, most with pictures. You have to open the dash and pull the instrument panel to change them out. It's easy but takes a while. Dealers will charge a few hundred in labor.
Old Jul 6, 2010 | 04:19 PM
vjaneczko's Avatar
Thanks
Did you test the lights in the instrument panel before you buttoned it all up? Did you use filament bulbs or LEDs? If it's LEDs, they do have a polarity so you have a 50/50 chance of installing them backwards.
Old Jul 10, 2010 | 10:13 AM
962ym's Avatar
Default Thanks for the info
I ordered two new bulbs from ipd. I just wish that those two bulbs would have been part of the instrument panel replacements when I ordered the bulbs to be replaced when repairing my odometer. Oh well - lesson well learned. Thanks!!
Old Oct 20, 2011 | 03:40 PM
mike1976's Avatar
Default led
if you have changed to led lights i found the best ones are from halfords the prism ones dont buy cheap ones of the web thay will only last a week or two and you will spend all your time changing them
Shelly
Jan 26, 2012 05:17 PM
zloetakoe
May 28, 2011 07:29 PM
njmotorguy
Apr 30, 2009 07:08 PM
ty672
Apr 30, 2009 05:18 PM
bootdagger
Dec 11, 2007 09:12 AM
