Removing 940 non turbo exhaust manifold
Old Dec 25, 2015 | 09:09 AM
correllkp's Avatar
Default Removing 940 non turbo exhaust manifold
Ok. So I could not get the water pump not to leak in the top hat gasket area. Decided to throw in the towel and take it to the garage to let them do it. Turns out that the leak is from the head gasket according to the garage smoke test. It must be right in the same area as the top hat because it is almost impossible to distinguish that the leak is from the gasket and not the top hat. Garage wanted 1300 minimum to replace head gasket....generally that means about 1600-1700 by time all is said and done. Decided that was too much and had the car towed home so I could do it myself when I had the time. Well, the weather in the NE has been phenomenally warm so thought I would jump into the job. I almost have the exhaust manifold off but there is a small copper pipe connected to the rear of the manifold and what looks like two nuts. Not sure which I should turn to remove the pipe. Any suggestions?
Old Dec 25, 2015 | 11:17 AM
lev's Avatar
lev
I've done several of these, and I don't recall such pipe...
What year is this car?
Picture?
Old Dec 25, 2015 | 12:16 PM
correllkp's Avatar
Default Pictures of copper pipe attached to exhaust manifold
Hi LEV
Pictures attached. Second pic is a little fuzzy but it is where the tube is connected to the manifold
Attached Thumbnails Removing 940 non turbo exhaust manifold-img_0447.jpg   Removing 940 non turbo exhaust manifold-img_0449.jpg
correllkp's Avatar
forgot to mention this is a 1994 940 sedan
Old Dec 25, 2015 | 02:08 PM
lev's Avatar
lev
I suspected that: the '94 and '95 have the "pulse air" and that's what that pipe is a part of.
Just undo the nut(s), whatever it takes to get the manifold off. I know, these types of exhaust nuts are a pain, may strip, so use a pipe wrench or at least a good six point. Also, may be soak it in PB Blaster or similar for a day to make sure it comes off cleanly.
Did you get all of the nuts off the manifold without breaking any studs?
Old Dec 25, 2015 | 02:22 PM
looks like the EGR pipe to me.
pulseair goes over the top of the front of the valve cover, with a "F" shaped thing, that plumbs onto 4 nipples into the head under the exhaust header ports.
Old Dec 25, 2015 | 05:32 PM
correllkp's Avatar
Default 940 cylinder head
[QUOTE=lev;423967
Did you get all of the nuts off the manifold without breaking any studs?[/QUOTE]
I managed to get the head off without disconnecting the copper tube. Now that I have the head out I may try to disconnect the copper tube as it should be easier to get to. The only reason is to remove the manifold at this point is to remove one or two of the broken studs that hold the heat shield. Also, along these lines one of the studs in the head also broke so I will have to get that out.
A couple of points for others who attempt this job. One, for the intake manifold, no where in all my searching was there any mention of two electrical connections and one hose connected below the intake ports but still on the manifold...i.e., they have to come off.
There is a metal strap underneath the intake manifold...this can be loosened towards the top of the intake manifold to make it somewhat easier to pull the intake manifold off the head.
As noted above there is no mention of the small copper tube at the back of the exhaust manifold. The tube appears to wrap around the head to a sensor underneath the intake manifold. Was able to wiggle head off without disconnecting small copper tube.
Now that I have the head off it does appear that the head gasket is broken in the corner area near the water pump top hat gasket so that is probably my problem...but I did note that as I was loosening the head bolts the one in that corner was already loose...not sure why...maybe the garage did it when they smoked tested the system.
Now that I have the head off are there any suggestions as to cleaning valves, or other areas? I bought a gasket kit so will replace all gaskets.
Old Dec 25, 2015 | 06:10 PM
again, that copper tube is the EGR. the part its connected to under the intake manifold is the EGR Valve, which is vacuum activated, as controlled by the EGR Modulator forward of the left strut tower.
Old Dec 25, 2015 | 07:39 PM
lev's Avatar
lev
If you decide to take the head to a machine shop they can remove the broken studs.
Strange to have a loose head bolt--usually they are all pretty tight! I doubt the shop did it--no reason to do that.
You don't have to use a machine shop unless the surface or valves look pretty bad or you suspect or know of overheating--even with one broken stud the ex. manifold should be alright. I have gotten away with two broken studs...
Whodda
Nov 6, 2014 07:21 PM
katman104
Jul 29, 2012 12:12 PM
phlosten
May 29, 2010 12:02 AM
volvo_s70
Mar 9, 2009 08:38 AM
ludeless
Dec 2, 2007 06:18 PM
