Removing door panel on a 945?
Old Feb 22, 2009 | 11:00 AM
Nagash_X's Avatar
Default Removing door panel on a 945?
I need help removing the inside door panel on a Volvo 945 (same interior as 740).
I can't seem to find all the screws/clips...
If anyone can help I'd be grateful!
Sincerely,
Nagash
Old Feb 22, 2009 | 11:17 AM
tedv's Avatar
3 clips on the bottom, use a small flat head, get down and look at them.
Unscrew plunger operating lock/unlock.
Undo plastic retainer inside door handle, 90 degrees turn.
Pry the plastic switch base CAREFULLY, then lift out the base plastic plate.
Slide out the speaker cover.
Pry out red lense on door's edge which doubles as a clip.
Remove panel, disconnect speaker wires and wire for light on edge of door.
Old Feb 22, 2009 | 11:20 AM
Nagash_X's Avatar
Thanks a lot!!
Sincerely,
Nagash
weismanfamily
Oct 8, 2013 01:35 PM
c70_patrick
Nov 4, 2006 12:02 PM
sgold
Aug 8, 2006 12:40 AM
soapboxhero
Apr 26, 2006 12:32 AM
