replacement brake line
Old May 29, 2014 | 12:23 PM
Andre_240's Avatar
Default replacement brake line
I'm trying to replace a front-passenger caliper. One of the line fittings has threads that look very warped and won't catch onto the caliper.
Is this a good replacement ? :
Volvo Brake Line Copper Front (Hose to Caliper) AA0320 | FCP Euro
I ask because the description says "copper" but I thought that would be soft?
thank you!
Old Jun 1, 2014 | 02:53 AM
modifierwong's Avatar
I can't say I have ever seen copper brake lines from the hard line to the wheel, but that's what the description says, curiously. Probably best to call them to make sure its not a mistake. I can't imagine the fatigue-life to be any good, nor a good idea at all to use a metal tube for this purpose. Brake flex lines are rubber or braided stainless steel for a good reason. If you've seen how much flex lines move when a car is in motion, you'll quickly understand the need for something much more flexible than copper.
Replacement rubber brake lines would probably work best for you.
Old Jun 1, 2014 | 03:06 PM
volvo brake hard lines /should/ be made of copper-nickel alloy, not straight copper. This is also known as cupronickel, volvo pioneered the use of this in the 1960s.
on the 240 non-ABS at least, there's a pair of short hard pipes from the brake caliber to a bracket where the flexible line is attached, something like this...
Old Jun 2, 2014 | 06:53 AM
act1292's Avatar
The FCP relacement brake lines are cupronickel but have steel fittings. If you purchase the brake lines from Volvo, they come with fittings that I assume are the same material as the lines.
I have used the FCP lines and have had no problems with them.
Old Jun 3, 2014 | 11:58 AM
Andre_240's Avatar
you guys are much faster than FCP or Volvo... thank you!
Old Jun 4, 2014 | 08:22 AM
That's a very interesting stock brake setup. I was imagining the hard nickel lines to be in place of the stainless braided flex line, which obviously won't work. You learn something new everyday.
Old Jun 4, 2014 | 09:20 AM
note that specific picture I posted was of a brake upgrade, some kinda bigger caliber from something. but the stock setup is similiarly plumbed.
Magnusson
Apr 15, 2014 07:00 PM
kaptinkafeen
Mar 18, 2011 02:24 PM
snpklinefelter
Dec 22, 2009 06:26 AM
Sepp
Nov 14, 2009 01:43 PM
martylandman
Feb 3, 2006 03:59 PM
