replacement bulbs fot the instrument cluster
Old Dec 15, 2013 | 08:29 PM
ms000's Avatar
Default replacement bulbs fot the instrument cluster
Is there any standard replacement for these bulbs?
I mean that I have the plastic thing, but the bulb does not work. I would like to buy some standard bulb and solder it in instead of the broken one. However at advanced auto parts they told me that this bulb is very small and they don't have any equivalent.. Does anybody know what's the voltage/wattage to look for?
Old Dec 15, 2013 | 09:16 PM
ms000's Avatar
P.S. Bulbs are from 240 90's instrument cluster.
Old Dec 15, 2013 | 09:34 PM
those big chain parts stores are pretty much worthless for anything they can't look up in their catalog.
I'm sure you could find a small 'grain of wheat' bulb the right size and solder it onto your plastic base, but are they really that expensive at IPD or FCP ?
Old Dec 16, 2013 | 09:50 AM
ms000's Avatar
Bulbs on the picture are 12$ each.. (here). On the other hand, I am guessing that may be these bulbs, which are just 2$/each would work out as well? Or am I wrong?
Old Dec 16, 2013 | 02:49 PM
I think those others have different bases, but yes, you could probably transplant them
Old Dec 17, 2013 | 03:08 PM
fochs's Avatar
Default This:
1990 Volvo 240 Instrument LED Lights | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs
Might as well be able to see the gauges when you're done.
Old Dec 17, 2013 | 03:21 PM
none of those will fit in the 240 instrument illumination spots without a lot of hackery.
Old Dec 17, 2013 | 03:39 PM
fochs's Avatar
Default Nothing wrong with a little hackery.
VWVortex.com - LED Dash Lights Tech Procedure:
Old Dec 17, 2013 | 03:56 PM
ah, k, they are smaller than I thought. thats still a fair amount of hackery
Old Jan 18, 2014 | 03:54 PM
ms000's Avatar
I didn't work out how to insert them and ended up soldering the diodes into the connectors from old lamps. As Pierce was saying, it was a bit of hackery.
crosby1
Jun 6, 2013 09:51 PM
volvo5volvo
May 29, 2012 05:46 AM
MattyXXL
Mar 26, 2011 10:19 PM
ty672
Apr 30, 2009 05:18 PM
ko_kidd
Aug 14, 2006 09:10 PM
