replacing the A/C controls on a 1993 940
I have a 1993 Volvo 940 turbo and one of the a/c control dials has broken. the one for the direction the blower pushes the air out. i have the replacement control box but i cannot figure out how to get the old one out of the dash.
would anyone be able to point me to a place with a video or detailed written instructions....basically for dummies?
TIA
Bel.
TIA
Bel.
its been a long time and I no longer have any 7/9, but IIRC, remove that trim panel that goes from teh ignition key across to around the HVAC controls, using a plastic trim tool to carefully unsnap it. leave the switches and wires connected to this facia plate, just let it hang out of your way. once that facia trim plate is removed, you can unscrew the HVAC control and remove it. I don't remmeber if that one has a control bowden cable, if it does, you may have to remove the glove box to disconnect the other end of said bowden cable. I'm sorta remembering the 940 is all vacuum operated, all the vacuum hoses should go to a sort of spider thing that unplugs from the back of the HVAC control panel as a unit, so you don't need to individually disconnect them and keep them sorted out.
I've tried bending the fingers out of the way and just can't find a way to get a grip on them to bend them. Certainly not in a way that's going to let me bend them back enough to close everything up.
I've gotten as far as pulling the radio out but can't get the case that holds the radio out so I can see any obvious way to remove the a.c. controls.
How would a service tech do it? Any idea?
pete8475
12-28-2010 08:51 PM
