replacing entire ignition switch
Old May 3, 2020 | 06:13 PM
Mike Engelman's Avatar
Default replacing entire ignition switch
I just acquired a 92 940 Turbo. The car was abandoned and the people who recovered it destroyed the ignition switch to disable the steering lock. I found a used one but cant get the old one out. Has anyone any experience with this?
Old May 3, 2020 | 08:50 PM
lev's Avatar
lev
It will probably have to be drilled out, carefully, depending on how much was damaged. There is another way to get it out, a pin holds the thing in but if destroyed, that's out, depends on the state of the damage. May be you can post a picture...
Old May 4, 2020 | 01:39 PM
if you get the lock out and a new lock installed, I believe you can still buy lock cylinders from Volvo keyed to match the car, ordered by VIN. I've had cars with different keys and its a pain, its much nicer when the same keys fit doors, trunk, glovebox, and ignition.
rgierer
1998-2000 model year V70
May 10, 2019 04:51 PM
blu72
Aug 27, 2011 10:41 AM
dezlorelle
May 20, 2011 11:51 AM
RPMCanes
Apr 24, 2009 07:22 PM
Carbuff
Jun 29, 2005 11:42 PM
