Ignition Switch won't return
Old Jun 29, 2005 | 08:17 PM
Carbuff's Avatar
Default Ignition Switch won't return
940 Wagon non-Turbo
In hot weather when I start the engine the ignition switch will not automatically return to the run position.
Aside from training myself to push it back after the engine starts, is there somewhere I can lubricate so the return spring has an easier time of it?
PS I assume this spring is in the ignition lock mechanism rather than the electrical switch...
Old Jun 29, 2005 | 08:42 PM
Default RE: Ignition Switch won't return
The spring is part of the electrical part of the switch.
You will need to replace the switch to get it back to 100%
You can try lubbing the lock cylinder to make it work for now.It might help and it might not.
Old Jun 29, 2005 | 11:17 PM
Carbuff's Avatar
ORIGINAL: tech
You can try lubing the lock cylinder to make it work for now.It might help and it might not.
I tried lock lubricant in the keyhole...no change. Oh well.
Thanks
Old Jun 29, 2005 | 11:42 PM
No problem.
rspi
Apr 4, 2009 09:05 AM
rspi
Apr 3, 2009 12:29 PM
tmixdorf
Jul 23, 2007 09:47 PM
