Replacing fuel line
Old Mar 29, 2010 | 11:09 PM
stumeston's Avatar
Default Replacing fuel line
Sorry if this has been covered before, I searched first but I couldn't find much on the subject. Has anyone ever had to replace the entire fuel line on their 240? Mine is leaking at a connection in the engine bay and is pretty cracked underneath the car so I want to replace the entire line from the fuel filter to the engine. If it makes a difference, the old diesel engine was swapped out for a Ford 302 Windsor V8 by the previous owner. He didn't mention if he had replaced the original fuel lines at the same time, but they look very old to me.
Old Mar 30, 2010 | 10:50 AM
bubba240's Avatar
What year? From what I've read on the brickboard, that section of line is a dealer-only item. You might look for one from a junkyard.
You can also look up the part number using this site:
www.getvolvoparts.com
Old Mar 30, 2010 | 07:15 PM
stumeston's Avatar
It's a 1980 240DL, I believe. The car has been debadged, but that's what the previous owner said it was.
Old Mar 30, 2010 | 10:52 PM
tedv's Avatar
In a car like that I'd throw the book out the window, literally and figuratively, and improvise. Just get a decent quality fuel line hose and adapt it to whatever you got in there. A possibly ex diesel Volvo 240 now with a Windsor v8 does take some special TLC...
Old Mar 31, 2010 | 08:28 AM
stumeston's Avatar
hahaha yeah, I figured I would have to improvise. I took a look under the car and it looks like it would be pretty simple to do, just unbolt from the filter and where it's leaking near the engine and bolt in some new line. What kind of line should I ask for, just high-pressure fuel line?
Old Mar 31, 2010 | 11:19 AM
tedv's Avatar
Yes, some fuel injection hose...make it fit! I go to NAPA.
Old Mar 31, 2010 | 06:36 PM
stumeston's Avatar
Awesome, thanks for the help everyone! I should be swapping the line out this weekend, I'll post the results when I'm done.
Old Mar 31, 2010 | 10:03 PM
stumeston's Avatar
I just had a look under the car, and it turns out I don't need to replace the whole line. The line runs from the filter to the firewall, and then it attaches to some metal tubing, and from there it is 68mm fuel injector line from the metal tubing to the engine. In total, I'm only going to have to replace about 3 feet of line, if that.
Old Apr 3, 2010 | 12:26 AM
redbottle's Avatar
junk yard part is a cheaper way for me....the cars are raised already and passing gas is ok.....every thing is dirty anyways....WHAT HAPPENS AT THE YARD STAYS AT THE YARD...
I think the bolts are 8mm
pretty easy....except for the whole tar covering....
smithnr
Apr 8, 2013 04:56 PM
CoVoVo
Oct 24, 2012 10:19 PM
megatrack
Jan 16, 2012 07:40 PM
haydenm315
Aug 30, 2009 08:36 PM
SilentBob
Nov 14, 2006 09:09 PM
