Replacing the Rear Main Engine and Transmission Pump Seals
Old Sep 8, 2013 | 08:10 PM
J Dubb's Avatar
Default Replacing the Rear Main Engine and Transmission Pump Seals
Hi, everybody. My 1991 240 is leaking transmission fluid from where the transmission and engine meet. I think it’s my pump seal. I know I need to replace the rear main oil seal as it is leaking too. Since the transmission has to come out to do both, is there anything else in there I should consider doing while the transmission is out? The pictures I’ve seen of the pump seal are very similar to the front seals that I replaced a few months ago. Is its replacement procedure about the same?
I have a friend with a lift and a transmission jack. Does anyone have good instructions on removing the transmission so that I can access the rear main engine seal and the transmission pump seal? This would be a great help and allow me to do this job myself and not have to pay someone. Thanks everybody.
Old Sep 8, 2013 | 08:57 PM
TIPSP's Avatar
Got Boost?
Kjet.org has the Volvo greenbooks in PDF. They have steps for transmission overhaul and removal/ install.
It's pretty straight forward, just requires some time.
winrid
Jan 4, 2015 12:53 PM
majorcode
Nov 4, 2013 06:41 PM
Alyssa1211
Dec 29, 2011 12:33 AM
Kaspir
Sep 13, 2008 06:27 PM
anubyss
Nov 2, 2005 11:47 AM
