Replacing the spark plug wires...
Old Nov 16, 2010 | 06:36 PM
Alexanderdickens's Avatar
Default Replacing the spark plug wires...
Hello, I'm considering doing a spark plug and wire change on my Volvo 940GL (non-Turbo) that I recently purchased. It's running a little rough at idle and I wanted to know how could I tell if I have a regina or bosch ignition system? Does it matter what type of wires I use to replace them?
Old Nov 16, 2010 | 07:19 PM
brickrunner's Avatar
Bosch have round ignition coils and Regina have square ignition coil. Kingsbourne, Bougicord, and Magnacor are good makers of spark plug wires.
Old Nov 17, 2010 | 02:29 PM
Thanks Brick, I see that I have the Regina coils so I'm going to IPD to order the set. I have another question. I noticed at normal operating temperature there is some heat blowing out of my front air vents. The temperature guage doesn't show that it's overheating and hangs in the middle. What could the be a sign of???
Old Nov 23, 2010 | 12:05 PM
740_300K's Avatar
The heat thing is normal. Air coming through the outside vents will blow in to the car. It's why even on a cold day, if you're running down the highway, you don't even need the blower motor running to keep the car warm inside.
Old Nov 30, 2010 | 09:05 AM
gigzilla47's Avatar
Default Re: Hot air from vents
Hi,
If you press the RECirculate button (the one on the right of the three heater/AC /defrost buttons) the hot air will stop blowing in through the vents.
futbolfan15
Apr 2, 2010 09:56 PM
colgate41
May 11, 2008 11:22 AM
MattB850in
Apr 13, 2007 11:12 AM
go2sharks
Feb 17, 2007 01:10 AM
defuse
Jul 18, 2005 10:34 PM
