Revamping the fuel system....which first?
Old Oct 3, 2009 | 10:59 AM
dman777's Avatar
Default Revamping the fuel system....which first?
Slowly, I am restoring my volvo 240 1990 dl. It has a 165k miles on it(at least i hope so, but i am worried it may of been a frankstien car put together at the volvo dealership/shop). I want to improve my idleing. It's is pretty smooth for the most part. But every once in awhile it will idle rough or be a little rough deaccelerateing. This isn't constant, but just once in awhile. Also, when I start my engine while it's hot from running previousely, the check engine light will come on for a sec and it will want to die out untill i give it gass. but this is only when the engine is hot.
here's what I did so far:
new fuel filter
New oxygen sensor
Tune up with new rotor cap and wires
new flame trap filter
new starter
new fuel pump
What should I replace first?
1)The fuel regulator
2)The idle motor
3)Air mass meter
4)Fuel injectors
5)in tank fuel pump
Old Oct 3, 2009 | 12:37 PM
blue goose's Avatar
I would clean the idle motor and the throttle body. Also check the accordion hose for leaks.
djforresta
Jul 4, 2010 11:15 PM
volvomang
Aug 23, 2009 02:13 AM
Bosshoff
Oct 26, 2007 05:09 AM
ko_kidd
Aug 25, 2006 08:53 PM
