Rough idle and bad fuel consumption
Old Aug 20, 2018 | 06:25 PM
turbo876's Avatar
Default Rough idle and bad fuel consumption
About 2 weeks ago my 88 744 n/a started running rough missing low idle black soot and rich fuel smell from exh pipe and feel a little when driving but no power loss i did a complete tune up about 3 months ago plugs wires cap and rotor fuel and air filter when this showed up i tested the coil primary read .93 ohms so i changed it to no help ive tried spraying either around looking for vaccume leaks no change but i pull fuel regulator vaccume line it idles a little better but still missing could it maybe the power stage and how do u test it thanks for the help
Old Aug 20, 2018 | 08:03 PM
jagtoes's Avatar
Check the water temperature sensor.
Old Aug 20, 2018 | 09:00 PM
i doubt its the power stage, a dead power stage almost always means no spark at all which means no starting.... or intermittent no spark causing stalling when it warms up.
Old Aug 21, 2018 | 12:54 AM
turbo876's Avatar
Is that the rad one or the block one
Old Aug 21, 2018 | 08:12 AM
jagtoes's Avatar
The block one in the rear under the manifold. It's basically the cold start choke and enriches the fuel mixture during cold starts.
Old Aug 21, 2018 | 11:58 AM
turbo876's Avatar
Ok ty ill try that
Old Aug 21, 2018 | 01:26 PM
test it, don't just randomly replace parts because they MIGHT be bad.
see the ECT stuff here, http://www.swedishbricks.net/700900F...Sensors,%20Etc
Old Aug 22, 2018 | 03:48 AM
turbo876's Avatar
That show 89 and up is there one for before obd 1
Old Aug 22, 2018 | 04:05 AM
pretty sure the resistance readings are the same for lh 2.2 and 2.4 even if the scale is a little different, a hot engine, should read like 200-300 ohms, while a room temperature engine should read 2000-3000 ohms, and a freezing cold engine should read maybe around 6000 ohms.
Old Aug 22, 2018 | 04:15 AM
turbo876's Avatar
I was just reading later after the page that was sent and seen a different page and it basicly said what was happening on my car was the ect rough running black smoke plus i need to use a coupon at a store so the sensor will cost me 10 so ill get it today but how do u remove the clip holding the plug on it
Old Aug 22, 2018 | 02:27 PM
i don't have a volvo anymore to double check, but many of those plugs, you press a square silver wire clip IN and then pull the plug straight out with a minimum of wiggling.
Old Aug 22, 2018 | 06:31 PM
turbo876's Avatar
Well i replaced the coolant temp sensor idle is normal now but still black smoke and a slight miss so its getting better
Old Aug 27, 2018 | 11:05 AM
turbo876's Avatar
Update drove to work this morning now no misses runs smooth but now acts like it either floods out or low spark till rpms get above 1500 then its fine untill rpms drop went to start at lunch now not doing it could be a heat related any help is appicrated
Radfordalum
Apr 9, 2019 12:12 AM
Brant
Mar 1, 2019 04:17 PM
Galaxy850Sunny
Apr 27, 2015 09:45 PM
iamnickcarter
Jul 25, 2012 03:23 PM
90240DLGA
Apr 21, 2010 08:18 PM
