Shift linkage adjustments, '90 740 GLE
Old Apr 27, 2011 | 05:35 PM
BGoins12's Avatar
Default Shift linkage adjustments, '90 740 GLE
Hi guys. I just purchased a 740 GLE 16 Valve that had "no reverse". Upon inspection I found that the shift linkage under the car seems to be out of whack. It looks like there is 2 adjustment nuts and a missing bushing or bushings that need to be replaced.
I need to know how to properly adjust these as well as replacing any missing bushings (Good place to buy them?). Hopefully someone can help me on this so I can get the car on the road. It drives, but all the gears are messed up.
Oh, and I believe this has the AW72L transmission.
Thanks!
Old Apr 28, 2011 | 12:18 AM
avguy's Avatar
You probably need two of these bushings in the linkage.
Shifter Linkage Bushing
Unless you or somebody else previously marked the linkage it's largely trial and error when it comes to adjusting.
You may not need to adjust the linkage at all, as the missing bushing(s) result in a significant amount of play in the shifter.
Old Apr 28, 2011 | 06:42 AM
BGoins12's Avatar
Thanks for the info.
I actually ordered the $7.95 bushing kit from FCP Groton that has all the bushings I need. But yeah, the shifter in general is very sloppy... none of the PRND21 positions feel right at all.
Now to post in the wanted section for a dome light... I almost had a fire. I was wondering why the Dome fuse was out... put one in and heard a zap and smoke started pouring out of the dome light. Found that the little circuit board on the dome light was completely fried... you can tell it's been like that for a while.
Old Apr 28, 2011 | 01:09 PM
avguy's Avatar
What color do you need?
I believe there's a 740 in my local junk yard.
Old Apr 28, 2011 | 02:04 PM
BGoins12's Avatar
It's a light tan or off white, but a gray or black one would do fine.
Old Apr 29, 2011 | 10:42 AM
BGoins12's Avatar
Anyone have any information on how to adjust the linkage? I just want to make sure it's right after replacing the bushings so I don't have to get back under there.
gabanja05
Jul 25, 2012 07:57 PM
BEG
May 20, 2012 11:26 PM
BGoins12
Apr 30, 2011 10:04 PM
scorpius
Jan 25, 2011 02:08 PM
bpeabody
Nov 22, 2003 04:13 PM
