Shuddering into Reverse!
Old Jul 8, 2006 | 03:52 AM
syncan's Avatar
Default Shuddering into Reverse!
Recently, I bought a 1995 850 Turbo with around 170,000 miles. The car was well kept and serviced regularly by the original owner. All fluids were changed when they were supposed to be changed; the oil in particular every 2500 miles. I've been driving it well for about two weeks now, with no problems of any sort. That being said, I cannot figure out what is going on...
On my way out of the parking lot at work, I noticed a severe shudder when I shifted into reverse and again when I shifted into drive. At first I thought this was nothing, perhaps just age... but when I finally got home, I tried messing around with it to see if it would shudder again. And shudder it did. The car practically lurched as it changed gears. Lately, I've been noticing a little hard downshifting here and there while driving... but this issue with the reverse is just rediculous. The car will back up just fine, but I'm more or less afraid to do it in the first place because that lurch into gear feels completely unnatural. There is definately something amiss here, but I'm in no position to know exactly what...
If anyone can offer any sort of help or advice as to what I'm dealing with here, I'd be very grateful!
Old Jul 8, 2006 | 10:47 AM
Default RE: Shuddering into Reverse!
How's the fluid level and color?
Old Jul 8, 2006 | 11:40 AM
t.d.'s Avatar
How about the driveshaft?
Old Jul 8, 2006 | 01:19 PM
robert213's Avatar
Replace ATF...
https://volvoforums.com/m_25657/tm.htm
And while you are at it...
Replace Themostat, Coolant Temp Sensor, and Heater hoses...
https://volvoforums.com/m_16392/tm.htm
Old Jul 8, 2006 | 01:30 PM
syncan's Avatar
I took it out for a short drive this morning to see how it handled... shifting is still a little rough into 3rd and 4th gear... and to my amazement, it actually shifted cleanly into reverse on the first try. On subsequent tries, however, there was the same jolt that I felt the other day coming home from work....
Fluid is looks to be an acceptable color. It still has some red in it as well as a high viscocity.
At this point I'm not entirely sure about the driveshaft- like I said, this car has been driving perfectly for the past two weeks... does this have something to do with the AT filter, perhaps?
Old Jul 9, 2006 | 12:50 AM
Possible but I doubt it.
Is the Kick down cable seized?
Check the driveshaft center support bearing and housing. That will almost cause the same thing.
BigGreen
Sep 16, 2009 05:11 AM
hrtrhb
Mar 26, 2009 07:52 PM
uncle
Dec 3, 2007 06:48 PM
Beardog
May 26, 2007 02:48 PM
cgerdeman
Feb 27, 2006 04:00 PM
