Shock absorber base?
Old Apr 28, 2006 | 12:07 AM
tupapison's Avatar
Default Shock absorber base?
Tech, Remember what i circled in red on my engine a while ago? that i said that when i turned the steering wheel the right one made a noise like a spring? Well i need to look for that on the internet to order it but i dont know the name, could you help please?
Old Apr 28, 2006 | 12:15 AM
Default RE: Shock absorber base?
Link me to the post.
tupapison's Avatar
here's the pic
This pic is a bit old hehe
Old Apr 29, 2006 | 12:50 AM
Spring seats or spring caps.
You will need all the peices.
There should be like 3 peices.
Old Apr 29, 2006 | 12:59 AM
tupapison's Avatar
Well the volvo dealership told me that it was gonna be $176 ea for that, So I GUESS they know what they are doing?
Old Apr 29, 2006 | 02:18 AM
You should need
1. 1273745 Washer
2. 1387188 Support plate
3. 1273746 washer
4. 3530341 Bearing
Not sure of the price but that should be the Part #'s
Do a search for Volvo Part#_________ and see if you can find a site that sells them.
Old Apr 29, 2006 | 02:43 AM
tupapison's Avatar
thanks a bunch! but why 2 washers?
Old Apr 29, 2006 | 11:16 AM
It was showing one top and one bottom.
Also look here.
http://www2.swedishpartswholesale.co...aring&dp=false
http://www2.swedishpartswholesale.co...+Mount&dp=true
Old Apr 29, 2006 | 03:50 PM
tupapison's Avatar
hmm, so in the first page i should buy what? and in the second?
how much for each of the things i need(total for each side)?
Old Apr 29, 2006 | 05:51 PM
You should have to order 2 of the $77.00 parts.
Old Apr 29, 2006 | 07:02 PM
tupapison's Avatar
on either page? thanks that will save me 200 bucks!
are they the same for left and right?
I dont have to order the bearings or anything else? just the:
Description: Strut Mount kit w/ brg.
Year: 1995
Model: 940 8-Valve
Quantity:
Price: $77.57
Core: $0.00
And thats it?
Old Apr 29, 2006 | 07:35 PM
If you read the discription you just wrote. It says Strut mount kit w/Brg (that will be the bearing)
So each one comes with it.
If you want to be 100% sure call them and make sure.
But that is what it looks like to me.
Old Apr 29, 2006 | 08:13 PM
tupapison's Avatar
call who?
Old Apr 29, 2006 | 08:20 PM
The people from the Site!!!
Old Apr 29, 2006 | 08:29 PM
tupapison's Avatar
>_>...gee >_>
Old Apr 30, 2006 | 03:33 AM
tupapison's Avatar
Tech, the mechanic said that i needed to replace that, he said replace the base of the shocks, so what you showed me should be it? let me explain again what it is, when i turn the steering wheel i hear a sound like if you were pulling a spring, and sometimes i even hear a sound like the wheel hit something very heavy but is because of that part, thats beacuse of the strut base right?
Also one question, should i change the coil springs? i mean they are 11 years old
Old Apr 30, 2006 | 10:57 AM
  #17
That should be what you need.
If you feel you need to replace the springs go ahead and do it.
Yes they are 11 years old but as long as the car wasn't driven for years with a blown strut the springs will be fine.
Old May 1, 2006 | 11:35 PM
  #18
tupapison's Avatar
Tech, can you please explain to me why does this piece makes the noise i was telling u about?
Old May 8, 2006 | 01:15 AM
  #19
tupapison's Avatar
What exactly is this part for? i mean whats the task of this part?
Old May 8, 2006 | 01:48 AM
  #20
That is the pivot point for the strut. When it is bad it has play in it and that is what makes the noise.It is slopping up and down.
getcates
Jun 18, 2013 03:09 PM
Laddie
Sep 17, 2010 02:05 AM
96850urbo
Feb 7, 2009 11:47 PM
maron96
Feb 27, 2007 01:35 PM
