Shudder at low speed 240 Wagon
Old Sep 26, 2023 | 04:34 PM
bhammontree's Avatar
Default Shudder at low speed 240 Wagon
Hi
I have a 92 240 Wagon that has recently developed a bad shudder when braking, and to a lesser extent accelerating. When I use the brakes above 20 MPH I don't notice any shudder, but when I get to 20MPH I get a bad shudder that shakes the entire car. It seems to originate somewhere in the back and move forward as I slow down. It drops off between 20MPH and 10MPH, but peaks again below 10MPH. I get a lesser shudder when accelerating until I get above 20MPH. I have recently replaced the front rotors and pads, and the back pads. The back rotors looked OK so I haven't replaced them yet. I also did the ball joints, inner and outer tie rod ends, and all of the other bushings in the front end. The bushings for the back end are on order. I just got new front tires and an alignment as well. The shudder doesn't present in the steering wheel it is more like the entire car is shaking.
Any ideas what this could be? I looked at the motor mounts and transmission mount (appear OK), but I may replace them if the rear bushings don't fix it. Any other ideas I can try while waiting on IPD Santa are appreciated.
Thanks
Old Sep 27, 2023 | 08:04 AM
act1292's Avatar
Check your drive shaft u-joints. More than likely one is frozen.
Old Sep 27, 2023 | 08:39 PM
I was able to rig a go-pro under the car last night and shoot some video. The angle of the differential was moving up and down a good bit (10-15 degrees). I think the bushings in the torque rods are shot letting the diff move around too much. I have the bushings on order and will replace to see if that fixes it. I also have the ones for the rear trailing arm, and the anti sway bar. As much as it is moving around it may have damaged a drive shaft U-joint as well, but one thing at a time.
Thanks
Old Sep 28, 2023 | 08:50 AM
act1292's Avatar
Trust me. It's your u-joints on the drive shaft. Can't say you don't need new torque rod bushings as well but the root cause is the u-joints. The grease dries up in them and the freeze up and bind.
Mvd1234
Oct 13, 2021 02:33 PM
white83glt
Mar 16, 2011 04:24 AM
iceracer46
Aug 30, 2010 10:12 PM
wurkin4it
Jun 13, 2007 11:07 PM
redstickin
Mar 8, 2007 10:12 PM
