Slid into a barrier and broke a wheel :( 93 940
Old Jan 21, 2014 | 07:50 PM
92_240_sedan's Avatar
Default Slid into a barrier and broke a wheel :( 93 940
Im wondering what size wheel and tire i will need to replace this. Unfortunately this was one of the alloys and cannot really afford to replace it so i will just have to find a steel wheel. I cannot read the tire size because it is dark and snowy and windy. Im just happy i did not snap an axle.
Old Jan 21, 2014 | 08:46 PM
Any wheel for a 2/7/9 has a 5 x 108mm bolt pattern, with a +20 or +25mm "ET" offset.
these are the standard wheels used on 200/700/900s
Volvo 200/700/900 Alloy Wheels
Aries, in the 15" category, are quite common on early 940's. you might be surprised what you can find if you look around. I sold a spare pair of Aries to a kid via craigslist for $100 ($50 each) and they even had (mostly bald) tires on them that held air.
Aries are 6J x 15.
the tire size on a 15" 940 is 185/65R15, but you can also use 195/60R15
IF you have 16" rims, 205/55R16 is typical.
14" wheels won't fit on most 940s as they won't clear the brakes.
Old Jan 22, 2014 | 12:00 PM
Aries are 6J x 15.
It looks like i have on some 205 60 r15's at the moment.
Old Jan 22, 2014 | 06:57 PM
admasters's Avatar
Where are you? I have Ares rims (in CT).
Old Jan 22, 2014 | 09:11 PM
205/60-15 are close to the right diameter too, they fit fine...
me, I'd probably go with the 195/60-15 as 185/65 is now a rare size, with very limited tire choice.
Nickshu
Feb 25, 2013 08:50 AM
bostonman
2001-2013 model year XC70
Feb 4, 2013 05:57 PM
sundance
Aug 12, 2012 08:27 AM
jpbaily1
Nov 2, 2008 05:35 PM
Ibblefribble
Nov 8, 2007 11:15 AM
