91 740 Turbo wagon voltage issue
Old Mar 30, 2009 | 10:13 PM
red_t5's Avatar
Default 91 740 Turbo wagon voltage issue
- from time to time the alternator output drops to 9v. Sometimes cleaning the regulator contacts fixes the problem. This time it didn't so I tried a known good regulator from another car and it didn't work either but was fine when I put it back it it's original car so I replaced the alternator/regulator with a rebuilt unit... same problem. Then after watching it idle for a while the alternator voltage went back to 13+v at the alternator terminals but was still reading 11+v at the battery. I was thinking ground so I made a good ground connection but no change. Today I have 11+ at the alternator and at the battery. Any ideas?
Old Mar 31, 2009 | 04:15 AM
Typhoon's Avatar
Sounds like either an internal alternator problem, like a shorting wire, or you have intermittent high resistance in the circuit from alternator to battery. Where are you measuring voltage at, alternator terminals?
Regards, Andrew.
kdren77
Dec 12, 2013 01:32 PM
ejpomeroy
Oct 4, 2011 06:06 PM
mcslexus
Apr 17, 2010 05:47 PM
artemis_f0wl
Apr 30, 2009 06:58 PM
Business_Socks
Feb 2, 2009 05:50 PM
