Squealing from the drive belts - pulley geometry off? 1993 Volvo 240 B230F
Determine which belt/s are making noise - I spray brake or carb cleaner on individuals belts - the slight wetness will momentarily change the noise, to figure out which ones are noisy - don't ever use anything that lubricates!
If alternator/ps or ac compressor alignment is off - replace the rubber mounting bushings. If you have the lower alternator mounting bolt out - notice how it's worn - people always leave the lock nut loose and the long bolt wears badly sometimes -
After that the best thing I have found to reduce noise - and not the safest - use a round file on the v edges of the belts - VERY CAREFULLY - while the engine is running - i think it roughs up the "glazing", the shiny parts of the belt that touches the v groove - try it (carefully) - it works
guest01
11-05-2011 10:11 PM
