new bosch alternator, pulley misalignmet
Old Jun 25, 2014 | 02:55 PM
bctom's Avatar
Default new bosch alternator, pulley misalignmet
When I bought my '96 850 it had a new bosch alternator. Everything was working okay. When I replaced the serpentine belt with a new one I discovered that the alternator pulley was misaligned.
The newer serpentine belts are made of a different compound that is less forgiving of misaligned pulleys and consequently the new belt is pretty chewed up. There is only about half the width of the belt left.
Before I wade into this and spend $90 on a new belt I want to find out why the alternator is not lined up properly. I checked with the local auto parts store and they confirm that the bosch alternator is the correct one. The pulley was swapped over from the original alternator so it's correct also.
I've looked over all the info on changing the alternator and there doesn't seem to be any way to screw it up like this.
Any body have an idea on what went wrong when the alternator was changed? Is there a method to adjust the alignment of the pulley? I've never read or heard of this anywhere else.
Any help is appreciated
Thanks.
Old Jun 25, 2014 | 03:53 PM
boxpin's Avatar
Picture?
Old Jun 27, 2014 | 04:03 PM
bctom's Avatar
On it's way.
Thanks
Old Jun 28, 2014 | 01:36 AM
bctom's Avatar
Here's a photo.
The top pulley is the power steering pump, the middle is the alternator, and the bottom is the A/C.
The left side of the belt is unscathed and still a straight edge. The right side of the belt is not straight due to the misalignment chewing the belt up. Chunks of rubber flying everywhere, a real mess.
Any ideas? Does the pulley on the alternator look like it's the correct one, and put on the right way as opposed to being put on backwards?
Old Jun 29, 2014 | 11:28 PM
gdog's Avatar
There's something under your pulley that doesn't belong there. Is that an extra shim?
Old Jun 30, 2014 | 01:12 PM
bctom's Avatar
I wondered about that but had no other photos for reference.
Does the pulley on other 850 alternators not look like that?
Is it possible to shim a pulley like that? I've never heard or seen it done. (Not saying it couldn't happen though.)
I'm starting to think I'm going to have to remove the belt and the pulley to see what's going on. Arrrgh! this is why I work on my vehicles myself. That, and because I'm cheap.
Thanks
migbro
Jun 14, 2012 07:41 AM
elimont
Apr 29, 2012 03:02 PM
guest01
Nov 5, 2011 10:11 PM
bruceam
Jul 12, 2010 07:28 PM
keenv70
Apr 29, 2010 09:49 PM
