SRS light reset?
Old Apr 5, 2006 | 04:42 PM
copterrob's Avatar
Default SRS light reset?
I have a 92 940. My seat belt inertial real got stuck so I took it out to look at it. I cleaned it up and it works fine now but durring this process I unpluged it from the SRS system and then turned on the car to adjust the seat for better access. This trigered the SRS light and I cant figure out how to turn it off. I pluged the connector from the DLC into the B block and got an error code of 1-2-2. I tried pushing the button for more than 5 seconds but the led never came on and the SRS light remains. What am I doing wrong.
Old Apr 5, 2006 | 10:48 PM
wojeepster's Avatar
Default RE: SRS light reset?
http://www.troublecodes.net/Volvo/
Old Apr 6, 2006 | 10:04 AM
copterrob's Avatar
Thank you for the reply wojeepster. The light that I have on is the airbag light (SRS), not the check engine light. I know the code indicates a problem with the belt tentioner which is fine now I just want to clear the code. I tried the same method of clearing codes that would be used for the ignition or fuel system and it doesnt work. I had a problem like this a few years ago and I payed the dealer $70.00 labor for 2 minuites work so Im trying to avoid that. Thanks for any help.
Old Apr 8, 2006 | 02:57 PM
ORIGINAL: copterrob
If you have a B terminal and there is a wire in #5 slot then you can use that method to read and clear the code.
Old Mar 29, 2007 | 03:20 AM
Mars's Avatar
ORIGINAL: tech
ORIGINAL: copterrob
Where is this? I have the same issue
Old Mar 29, 2007 | 04:10 PM
billofdurham's Avatar
For the location of the OBD1 diagnostic unit check: https://volvoforums.com/m_57089/tm.htm
I posted a full how-to in there. However, there is no B5 terminal as there is only one box on the 940.
There is a test unit for the SRS system but it is located in the fuse box. Because of the possible danger of setting off the air bags I am very cautious about posting this information unless you feel that you are confident enough to do the job.
If you require more info, ask.
Old Mar 29, 2007 | 11:13 PM
Mars's Avatar
ORIGINAL: billofdurham
I think i can handle it. Just let me know the risks.
Old Mar 30, 2007 | 07:24 PM
The main risk is accidentally triggering the airbags. Most of the tests stipulate no 12v. However, for the SRS light test you need to use a digital volt meter to read voltage.
These are taken from a manual so I hope that they are clear enough to read. I have had to reduce them to get them to fit.
[IMG]local://upfiles/4491/257CB7669E5348A99AC143F9061E75BA.jpg[/IMG]
[IMG]local://upfiles/4491/056B7EEC7F2F45A09191DAD851BB73AF.jpg[/IMG]
[IMG]local://upfiles/4491/8EB9E5ED03044ACAB8AFD13F6653BAD0.jpg[/IMG]
[IMG]local://upfiles/4491/39A90C50870C41B289518FF2977BD8E2.jpg[/IMG]
[IMG]local://upfiles/4491/E70051DF285744D9B17DE493F78AB9A1.jpg[/IMG]
Old Apr 6, 2020 | 11:57 AM
Jason Chouinard's Avatar
Default Clearing SRS Airbag warning
Is there an ap that can clear the SRS code or do I have to but a better scanner? There are a number of aps and I've tried Torque Pro, Car Scanner Pro and a couple of free ones...
Old Apr 6, 2020 | 01:25 PM
depends on what year/model your car is. OBD2 is available from MY 96 on, some prior years have the OBD1 jumper/led button set up which can be used (the jumper port selects which code sets etc). Details for the early years may be on the volvotips.com site.
Old Apr 6, 2020 | 10:19 PM
lev's Avatar
lev
It depends on year of your Volvo. Please describe more in detail!
Old Apr 6, 2020 | 10:52 PM
Originally Posted by lev
it depends on year of your volvo. Please describe more in detail!
2005 v70
Old Apr 7, 2020 | 04:07 PM
you can read/clear SRS codes using a fully featured OBD2 code reader. Not all readers can do SRS codes so what I would do is check in with Autozone or similar and see if the rent (or loan) an ODB2 code reader that supports reading/clearing SRS codes. You can also see if a local indy shop will scan/clear for free (mine will). Last option is to buy your own code reader - probably run $100 for a unit that can do SRS codes.
Old Apr 7, 2020 | 04:50 PM
This is the 240/740/940 forum, last of these cars was sold in the USA in 1995, pre-OBD2
on our 940s that have SRS, the code clears when you fix the cause, there's no 'memory'.
Old Jun 18, 2021 | 08:08 AM
which module did you check to grab the codes? There's no 300 series codes for the SRS module from what I've seen. A 223 SRS code says there's a short in the passenger side airbag.
https://www.volvoclub.org.uk/faq/EngineOBDCodes.html
Old Jun 18, 2021 | 11:24 AM
lev's Avatar
lev
Try to reset the SRS first, may be it won't come back... Many times electric anomalies will set off lights that can be cleared successfully. BTW a 1990 740 doesn't have a passenger side airbag so a 223 code cannot be right.
Old Jun 22, 2021 | 10:12 PM
  #17
vermont22's Avatar
I used the module under the hood. I will check the fuse for the srs to flash the correct code
MSP850T
Apr 6, 2020 06:51 PM
marvgt95
Dec 28, 2009 05:14 PM
cava
Jul 29, 2006 12:27 PM
JimKW
Jul 26, 2006 08:49 PM
elbert
Jul 4, 2005 02:58 AM
